Gerber "Basic Multi-Function Survival System"
Knifecollector
Messages
313
This tough, heavy duty survival system is designed to withstand heavy use under the most extreme conditions. The 9" blade is ground from tough 1/4 inch thick high carbon surgical stainless steel, with Rockwell hardness of c54-55. We have purposely lowered the hardness several points to increase toughness. The blade and stainless steel guards and but cap are treated with a non-reflective finish. The butt cap is specifically designed to endure heavy pounding, and is firmly attached to the full length blade tang. The most unique feature of the BMF is its revolutionary handle of highly compressed DuPont Hypalon. Hypalon's semi-soft composition cushions the hand during heavy use, and provides a comfortable positive grip. Each BMF is hand-adjusted so that the point of balance is approximately at the front guard, which makes it comfortable to use, even during extended periods of heavy usage.
Das BMF wurde von 1986 bis Ende 1998 produziert.
Stahl: 440A (RC54-56)
Klingenlänge: 22cm
Griff: DuPont Hypalon
Scheide: Cordura inklusive einem Kompass in der Vortasche
attachment.php
Back
