Anzeige
Anzeige
Seite 2 von 2 ErsteErste 12
Ergebnis 31 bis 49 von 49
Thema: Sharpening with Paper Wheels
  1. #31
    Registrierter Teilnehmer
    Registriert seit
    22.07.07
    Ort
    Niederlande
    AW: Sharpening with Paper Wheels
    Anzeige
    The owner of this Sebenza 25 bought the knife brand new from a dealer in the Netherlands, but although he was and is still very pleased with the knife itself, he soon found that the factory edge didn't cut too well.
    He tried to improve things with the help of a Spyderco Sharpmaker and a leather strop loaded with some green compound, but to no avail.
    So he sent the knife to me, and the first thing i did was to measure the edge angle with my Tormek WM200 Angle Master.
    According to this device the edge measured 50 degrees inclusive on the straight part of the edge, going up to 55 degrees inclusive from the belly to the point.(!)
    This is how the knife looked before sharpening:
    First i removed the apex of the old edge by cutting a few times lightly at a 90 degrees angle into an old silicon carbide stone, after which i reprofiled the edge freehand on my Tormek SB-250 Blackstone to an even 30 degrees inclusive.
    This was followed by a Paper Wheel with 220 grit SiC to smoothen the grindlines made by the Tormek, then refined with a second Paper Wheel coated with 15 micron diamond compound, and finally removed the burr with a third Paper Wheel coated with 0.25 diamond compound. (this leaves the 15 micron scratch pattern intact as much as possible to preserve bite)
    The resulting edge treetops the hair on the back of my hand, can slice single-ply toilet paper, and survives a few cuts into my laminated testblock without any visible damage (checked under bright light with the loupe in my Victorinox SwissChamp)
    This is how the knife looks after sharpening:
  2. # Anzeige
  3. #32
    Registriert seit
    22.07.07
    Ort
    Niederlande
    Right hand Takamura R2 Gyuto 210 mm from a local Chef, who got it as a birthday present from his wife.
    The knife has already been used for two months in the commercial kitchen and it was time for it's first resharpening, which i did yesterday on a Paper Wheel with 15 micron diamond compound and then deburred on a second Paper Wheel with 0.25 micron diamond compound.
    The idea was to make an edge that would do both slicing & pushcutting well, and also to remove as little steel as possible from the fine and thin R2/SG2 blade @ 63-64 HRC.
    The new edge measures +/- 20 degrees inclusive and can whittle a chest hair from root-to-tip at about 4 centimeters from the point of holding, and after a few test cuts into a old piece of beechwood cutting board.
    I took these pics with an old Ipad and actually wanted to erase them again as being not good enough until i enlarged the last picture twice.
    At first i thought i saw small dirt spots on the new bevel, but those tiny white specks were actually the sliced off peaks of the micro-dot structure on the inside of the flimsy plastic blade protector sleeve.
    The owner of the Takamura R2 just sent me the link to this clip, in which he uses a grape to test the new edge:
    https://m.youtube.com/watch?v=ID9KZW...ature=youtu.be
    Update:
    According to the Chef this edge done on Paper Wheels lasted him 2 months in his commercial kitchen, which was just as long as the factory edge had lasted him.
    During that time he sometimes touched up the edge by stropping it on an MDF strop with 1.0 micron diamond compound until that no longer worked satisfactory (in the last week or so), after which he used a fine ceramic rod on it.
    Differences with the factory edge were that the Paper Wheel edge had a slightly smaller edge angle (+/- 20 degrees inclusive instead of +/- 22,5 degrees inclusive), was finer polished, and had a higher sharpness.
    We're still in the process of finetuning the edge to his specific requirements, and next time he brings in the knife it will probably get a little less refined edge to see if it's useful life can be prolonged a bit more.
    In his kitchen the real edge killers are the mandatory plastic cutting boards which are very abrasive on knife edges, together with the almost unavoidable tiny sand particles which sometimes remain in the huge quantities of vegetables that need to be processed.
    Geändert von kwakster (03.02.19 um 15:38 Uhr)
  4. #33
    Registriert seit
    22.07.07
    Ort
    Niederlande
    Some time ago one of the Chefs i sharpen kitchen knives for decided to treat himself to a brand new Sebenza 25 from a well known Dutch knife shop.
    As many here know the Sebenza is a beautifully designed & manufactured knife, and the model 25 is no exception.
    Sadly the factory edge on the first example the Chef got to handle was just plain blunt, and upon inspection it turned out that the other 4 or 5 Sebenza's 25 that the shop had in stock suffered from a comparable bluntness.
    To cut a long story short: in the end the Chef liked the knife so much that he just bought the least blunt one, while the shop assistant promised to contact CRK to see if the other knives could be sent back.
    The day after buying the knife the Chef visited me to ask if i could do something about the edge.
    The first thing i noticed about the blade on his model 25 is that it seemed to be ground a hair thinner behind the edge compared to previous Sebenza's 25 that i've handled and sharpened, and that as a result the edge bevels were quite narrow, even with a measured inclusive edge angle of 35 degrees.
    The second thing i noticed (with my Victorinox loupe) was that the edge reflected light almost along it's entire length, and i couldn't even cut a piece of copy paper with it.
    I think that the edge wasn't completely apexed, but with only my loupe to judge by i'm not 100 % sure.
    In a conversation with the owner and also because the knife was brand new we came to the conclusion to give it a new edge that would resemble the factory edge as much as possible, and to make it seem as best as i could that nothing was done to the knife.
    First i removed the blunt apex of the factory edge by cutting several times into a silicon carbide stone, after which i gave it a completely new edge with an experimental Rubber Wheel coated with 230 grit diamond powder & wax, after which i removed the tiny burr with a Paper Wheel with 1 micron diamond compound.
    The new edge again measured 35 degrees inclusive from heel to tip, survived a few cuts into my laminated test block without visible damage to the apex, which could then still easily treetop the hair on the back of my hand.
    And most importantly, the Chef was happy with how his new knife turned out,
    Before sharpening:
    After sharpening:
  5. #34
    Registriert seit
    22.07.07
    Ort
    Niederlande
    An older one, a user custom Jens Anso from a Dutch knifeforum member after a tune-up by a Dutch knifemaker.
    Part of the tune-up was a two-step stonewash treatment of the RWL34 blade, which unavoidably also removed the original edge.
    I put on a new edge using a standard Paper Wheel with silicon carbide grit, refined it with a second Paper Wheel coated with 15 micron diamond paste, and finally removed the very small burr on the Tormek leather wheel with some 1 micron diamond compound
    This leaves an edge that looks almost polished, but has more bite than when finished with the polishing Paper Wheel using standard aluminum oxide.
    Before sharpening:
    After sharpening:
  6. #35
    Registriert seit
    22.07.07
    Ort
    Niederlande
    A while ago i sharpened this Buck Hartsook in S30V steel for a Dutch forum member:
    The edge was done on Paper Wheels with diamond compounds exclusively, and the new & slightly convex edge measures +/- 30 degrees inclusive.
    Remarkably useful little knives with well hardened S30V steel.
  7. #36
    Registriert seit
    22.07.07
    Ort
    Niederlande
    A Strider SMF with S110V blade from a Dutch forum member.
    According to my Tormek angle gauge the old edge measured +/- 40 degrees inclusive from the heel to half an inch before the tip where it changed into 45 degrees inclusive.
    The owner uses this knife mostly to cut various kinds of green wood & twigs in horticulture, and had already tried his hand at reprofiling the edge himself with a DMT Diafold.
    Together we came to the conclusion that the edge could do with a full reprofiling, as well as with a finer edge finish to better suit his specific purposes.
    BTW: the owner also contacted Duane Dwyer by mail, among other things to ask him about the hardness of this S110V blade, and according to Duane it measures 61 HRC.
    This was the knife before sharpening:
    After reprofiling & sharpening.
    The new edge angle came out at +/- 32 degrees inclusive along the entire edge, and it can treetop armhair and slice single ply toilet paper.
    Probably due to having the flu at the moment my hands didn't do exactly what i wanted them to do, and as a result i didn't manage to get both bevels completely symmetrical.
    Grit progression: a Paper Wheel with 220 grit SiC for reprofiling, a second Paper Wheel with 15 micron diamond compound for refining, and a third Paper Wheel with 0.25 micron diamond compound for removing the tiny burr.
  8. #37
    Registrierter Teilnehmer MF-Mitglied
    Registriert seit
    11.07.05
    Ort
    NRW
    Re: Sharpening with Paper Wheels
    Ist die Konsistenz der Papierscheiben mit hartem Holz zu vergleichen?
    Oder sind die doch weicher?
  9. #38
    Registriert seit
    22.07.07
    Ort
    Niederlande
    Die Paper Wheels Scheiben sind weicher als hartem Holz, und auch noch etwas weicher als MDF.
  10. #39
    Registriert seit
    22.07.07
    Ort
    Niederlande
    A small black ceramic backlock folder without any markings (Böker ?) i did in 2013.
    This well made knife had practically no edge and no point to speak of when i received it, and even opening mail with it was difficult.
    I used the Tormek Blackstone graded to around 1000 grit for freehand reprofiling, followed by 3 Paper Wheels coated with 15, 6.0 and 3.0 micron diamond compounds for refining & polishing.
    The new edge fits in the 30 degrees inclusive slot on my Tormek angle gauge, is slightly convex, and can shave the hair on my leg in both directions.
    Specs:
    Length open: 12,0 cm
    Length closed: 7,5 cm
    Blade material: black zirconium oxide
    Blade length: 4,5 cm
    Blade thickness: 2,0 mm
    Handle material: Ivory Micarta & Nickel Silver bolsters
    Weight: 61 grams
  11. #40
    Registriert seit
    22.07.07
    Ort
    Niederlande
    Another oldie from 2013.
    A niece of mine is an avid amateur Chef (but not yet a knife afi), and this black ceramic knife is one of her favorites in the kitchen.
    Longtime use however (not always on a suitable cutting board) plus storing it unprotected in a drawer between a bunch of steel bladed knives had blunted the edge to a point next to unusable, complete with quite a lot of (micro) chips and a broken tip.
    This is the knife as it was when i received it.
    (when you click the pictures 2 x you can see the chipping & the damaged point clearly)
    This is the knife after sharpening.
    Removing the chips and setting the new bevel was done with a Tormek T7 fitted with an SB-250 Blackstone, refining with a Paper Wheel coated with 15 micron diamond compound, and semi-polishing with a second Paper Wheel coated with 6 micron diamond compound.
    The new slightly convex edge measures +/- 25 degrees inclusive, and the sharpness is just hairwhittling (only towards the root, not to the point)
    It easily slices single layer toiletpaper (torn apart 3-layered version) and a tomato of course.
    Specs:
    Overall length: 28,0 cm
    Blade length: 14,8 cm
    Blade thickness: 1,84 mm
    Blade type: black ceramic / saber-hollow
    Thickness behind the edge: 0,4 mm
    The first clip shows the slicing of a piece of standard 3-layered toilet paper, for the second clip i peel off 1 layer and slice the remaining 2 layers, and the third clip shows the slicing of just the remaining single layer of toilet paper:
    http://www.youtube.com/watch?v=Ubg_drYHoKE
    http://www.youtube.com/watch?v=hUkKfwGFogY
    http://www.youtube.com/watch?v=RSkxPA9BK8E
    Slicing a tomato:
    http://www.youtube.com/watch?v=R3-A0SMcIbw
  12. #41
    Registriert seit
    02.01.19
    Ort
    NRW
    Found this... maybe it is interesting?
    http://knifegrinders.com.au/SET/Effe..._retention.pdf
  13. #42
    Registriert seit
    22.07.07
    Ort
    Niederlande
    I've read it myself some time ago, but it is indeed interesting reading material for people interested in sharpening with Paper Wheels.
    Guess who Vadim got the idea of using Paper Wheels with diamond compound from ?
  14. #43
    Registriert seit
    02.01.19
    Ort
    NRW
    Ok...
    I understand...
    By the way... did you receive my email I sent some days ago?
    Cheers
    Geändert von Schärfefan (25.05.19 um 08:32 Uhr)
  15. #44
    Registriert seit
    22.07.07
    Ort
    Niederlande
    Just changed my e-mail address, so you could try again.
  16. #45
    Registriert seit
    11.07.05
    Ort
    NRW
    In this short article is no definition of BESS and what compound was used on either wheel.
    Is it in some of the linked studies?
  17. #46
    Registriert seit
    22.07.07
    Ort
    Niederlande
    Italian made A.G.A Campolin Maltese stiletto from a collector.
    The knife was recently bought brand new from a foreign shop, but it came with quite a lot of blade play, a very rough ~55 degrees inclusive "edge" with a big burr still attached to it, and no point at all.
    Also both sides of the blade aren't mirror images of each other, with a center ridge that is off a bit on one side.
    Anyway, especially the lack of a point bothered the owner, the bad edge came in second, and fixing the blade play will probably be a job for another day.
    This is how the knife looked before resharpening:
    And how the knife looks now.
    While keeping the edge angle about the same so the bevels would not widen too much per owner's request, i resharpened the main edge completely and the bayonet grind only superficially to come to a sharp point with a 15 micron diamond compound Paper Wheel, then cleaned up the bevels a bit and removed the tiny burr with a 1.0 micron diamond compound Paper Wheel.
    The edge angle again measures ~55 degrees inclusive, yet the new apex is just sharp enough to shave the hair on the back of my hand a bit on skin level.
  18. #47
    Registriert seit
    22.07.07
    Ort
    Niederlande
    The first owner of this small Sebenza apparently thought it a good idea to use the knife for sharpening practice in his new Wicked Edge.
    The outcome made him sell the knife for a measly 150 Euro's to owner number two, who sent it to me with the request to tidy things up a bit and give it a bit of a shiny edge.
    Below is what the knife looked like when i received it, still with it's very rough and partly unapexed "edge", and with an edge angle of ~40 degrees inclusive at the straight part of the edge, changing into ~45 degrees inclusive from belly to point.
  19. #48
    Registriert seit
    22.07.07
    Ort
    Niederlande
    After reprofiling & sharpening on a Paper Wheel with 15 micron diamond compound, then deburring and polishing it a bit with a second Paper Wheel coated with 1.0 micron diamond compound.
    The new edge is a bit convex, and measures ~30 degrees inclusive on the straight part of the edge, changing into ~35 degrees inclusive from belly to point.
    This to avoid widening the bevels there too much, as this blade is relatively thick behind the edge in that area.
    The last picture shows a small facet at the heel which has an entirely different angle, so i could not remove it without making things worse.
    Visually it's not perfect yet treetopping sharp, and the owner was happy.
  20. #49
    Registriert seit
    22.07.07
    Ort
    Niederlande
    Anzeige
    User LH Sebenza Micarta with it's blade made from Devin Thomas stainless basketweave damascus (AEB-L and 304)
    Reprofiled & sharpened the old slightly convex edge with it's apex @ ~40 degrees inclusive into a new slightly convex edge with an apex @ ~30 degrees inclusive on a Paper Wheel with 15 micron diamond compound, then removed the extremely fine burr on a piece of copypaper with a dab of 0.25 micron diamond paste.
    The new apex is reverse chest hair whittling sharp and the new point is also quite close to being centered.
    To my functioning eye the bevels look near-mirror like, but the camera sees a bit blotchy scratch pattern due to the different layers in the damascus steel.
    Before:
    After:
Aktive Benutzer
Aktive Benutzer
Ähnliche Themen
  1. Blue paper
    Von Denis Mura im Forum Galerie
    Antworten: 1
    Letzter Beitrag: 01.11.15, 17:01
  2. Mammut On The Wheels Of Steel
    Von andr.stan im Forum Richard Kappeller
    Antworten: 8
    Letzter Beitrag: 02.09.11, 11:55
  3. SOG Stingray Mino Paper
    Von herbertlisi im Forum Kaufberatung
    Antworten: 4
    Letzter Beitrag: 17.06.09, 18:53
  4. Papierräder (paper wheels) - Sinnvolle Schärfmethode?
    Von Morales im Forum Wartung & Pflege
    Antworten: 11
    Letzter Beitrag: 12.05.09, 02:35
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
