roman schrieb:H1 wenn du den meinst (x6CrTi 12) 1.4512 ist ein ferritscher Chromstahl und zählt zu den hitzebeständigen Stählen mit verringerter Zunderbildung nimmt man z.b. für Auspuffe.
Ist also mit 0.06%C nicht härtbar und durchaus recht korrosionsbeständig jedoch das Titan verhindert die Zuwanderung von Sauerstoff und gibt ihm damit seine Korrosionsbeständigkeit auch bei höheren Temperaturen.
Für Klingen ist er ungeeignet.
0.15 Carbon / 14.00-16.00 Chromium / 2.0 Manganese / 0.5-1.5 Molybdenum / 6.00-8.00 Nickel / 0.1 Nitrogen / 0.04 Phosphorus / 3.00-4.50 Silicon / 0.03 Sulfur
Angeblich soll der Stahl beim Schärfen geringfügig härter werden "work-hardening while sharpening and processing", kannst du da etwas zu sagen?
TazKristi schrieb:Keno,
Sal is out of the office for Blade... we did test X-15TN, H1 met our standards better so we chose it. Here is a post I made quite some time ago that might help with the Rc info...
TazKristi schrieb:H1 is a precipitation-hardened alloy. And yes, it is also work-hardened. Meaning that anything that you do that causes heat through friction will harden the steel further; it’s also important to note that tests have shown that it does not become brittle. The work-hardened properties of H1 have been proven by analysis independently performed by Crucible Specialty Metals. It is this that explains why an H1 blade with a SpyderEdge has better edge retention than it's PlainEdge counterpart. In the end, the analysis from Crucible found the Rc at the spine was 58, however at the edge it had increased in both the PlainEdge (to 65 Rc) and the SpyderEdge (to 68 Rc).
The Salt Series knives are being made and promoted to a market where corrosion resistance is important.
So, is H1 possibly just another flavor-of-the-month? Possibly, but hype can only go so far.
Kristi
Check die Chemie!!!!
roman schrieb:Klingt bei der Chemie noch unmöglicher.
