Jenni
Moderator Forum Kizlyar und BRKT
Hier werden wir wie schon in den Vorjahren den Produktionslauf für das Jahr 2012 veröffentlichen.
Der Produktionslauf unterliegt wie immer Schwankungen, das heißt: es kann immer mal wieder das ein oder andere Modell vorgezogen oder zurückgestellt werden.
Index:
Delivered The run is over and shipped to the Distributors- ausgeliefert
Delivering The run has started to ship and will continue to ship until 100% shipped to the Distributors - in der Auslieferung
In Assembly The blades are totally ready for starting to build the run- Griffmontage
In Blade Grinding The Blades are having the Rough Initial Grind put in them-
In Surface Grinding The Blades are being uniformly surfaced so that they are flat and have all of the heat treat slag removed from them
In Heat Treat The Blades are in the process of being heated - Quenched - Cryo Treated - Triple Tempered - Straightened and then Shank Drawn to soften the tangs
In Water Jet Cutting The Steel is Delivered and the job is in line for Cutting and then Drilling out the Holes.
Pocket Bravo - 154CM - sind schon unterwegs zu uns
New Drop Hunter - A-2 In Assembly
Trail Buddy III - In Assembly PIC
500 BJK Tac-Ops 4 In Assembly
500 BJK Tac-Ops 6 In Assembly
500 BJK Tack Ops 8 In Assembly
STS-5 - In Assembly
Scandi - In Assembly
Bravo-1 S35VN Fill In - In Assembly PIC
100 More A-2 Goloks - In Blade Grinding
Magnum Fox River - A-2 - In Blade Grinding
Mini-Fox River CPM 3V - In Surface Grinding
Gunny 3V - In Surface Grinding
Bravo-1.5 S35VN In Surface Grinding
Bravo-1 CPM 3V Field Rampless Model DLT - In Blade Grinding
Bravo-1 CPM 3V Std Model - In Heat Treat
Bravo-1.5 3V - In Heat Treat
Bravo-Necker - 3V Satin Finish - In Heat Treat
Mini-North Star CPM3V - In Water Jet Cutting
Bravo-1.5 A-2 PIC In Water Jet Cutting
Trailmate - 3V
Trailbuddy CPM 3V
Essential M-4
Essential II M-4
Gameskeeper - Montana Guide
North Star Companion CPM 3V
Liten Bror CPM3V
Bravo-II 3V
Grasso Bolo - I
Lil' Canadian CPM3V
Gameskeeper II - Montana Guide II
Little Creek - CPM3V -
STS-4 DLT
Bravo-III 3V - Steel Ordered(.275" + 3V)
Hybred - Aurora/Canadian Special - CPM3V - KSF
Grasso Bolo - II
Kephart 5 3V -
STS-2
Rogue - Steel Ordered(.235+ A-2)
Nasty Kukri Prototype Run
Ultra Light Bushcrafter - CPM 3V
BJK Tac-Ops 5 - 1095
BJK Tac-Ops 7 - 1095
Pro-Scalpel II - Steel In House(.170+" A-2)
Wilderness Explorer S35VN (Full Tang River's Edge Style)
Pro Series Brush Knife A-2 PIC
Rogue Bowie II - Steel Ordered(.265-A-2)
Mikro-Canadian A-2
Scagel Small Hunter & Bowie A-2
Canadian Camp Knife II(.235" A-2)
Grasso Bolo III
Mini-Rogue
Canadian Sportsman A-I - 154CM
Pioneer 8
BJK 14-8 Attack Knife
Mini Special Hunting Knife
Moro Barong
Mini-Grasso-Bolo
Bravo-2.5
And Much More
und vieles mehr.......
Bitte beachtet, das der Produktionslauf nur ein ungefährer Anhalt ist, es kann jederzeit etwas vorgezogen, eingeschoben oder zurückgestellt werden.
Grüße Jenni
bezüglich des Folders , habe ich noch keine Neuigkeiten, er ist aber nicht wirklich auf Eis gelegt.
Index:
STS-5 - In Assembly
Trailmate - 3V
Trailbuddy CPM 3V
Essential M-4
Essential II M-4
Liten Bror CPM3V
Bravo-II 3V
Grasso Bolo - I
Lil' Canadian CPM3V
STS-4 DLT
Grasso Bolo - II
Kephart 5 3V -
STS-2
Mikro-Canadian A-2
Grasso Bolo III
Mini-Rogue
Pioneer 8
Moro Barong
Mini-Grasso-Bolo
Bravo-2.5
And Much More
Grüße Jenni
